Windows Server Forum
Windows Desktop
Windows 10
Missing 'Mail' icon in Control Panel. Not under 32-bit, tried searching
Joined: 08/01/2017(UTC) Posts: 664  Location: London Thanks: 17 times Was thanked: 6 time(s) in 6 post(s)
I am on Windows 10 Pro
Office 2019
I have NO control panel>mail icon
Even when I search or try and find any reference to 32-bit
My Office 2019 is 32bit
What can I do? |
If you ever wanted to thank us, you can send us Bitcoins using:12G4A52Znm5s35buKDEmKU2p2vQY69Nsyo
OK so just to say I looked for the file under the program files directory and it is still there:
"C:\Program Files (x86)\Microsoft Office\root\Office16\MLCFG32.CPL"
And if you double click it, you can still configure outlook 2019 OK
I will look into restoring it in the registry |
If you go to this page: https://www.microsoft.co...ivetab=pivot:overviewtabYou can download the control panel GUID creator from the Microsoft Store for Windows 8/10 + Copy your generated GUID and open RedgEdit.exe as a computer administrator, as you will need to be able to make changes to HKEY_CLASSES_ROOT Go to HKEY_CLASSES_ROOT\CLSID (Which is after all of the ones beginning with a period or full stop) Right click on the CLSID key and choose NEW>Key and paste in the GUID from the GUID tool in these brackets {} :  Double click the 'Default' and in the value box, type the name of the Control Panel item as you wish it to appear. Create another string in the same key called InfoTip and enter a useful tip for anyone using the item Now click on the root key of your new item (the one you copied the GUID into) and create another key within it called DefaultIconReferencing Microsoft Windows Icon Reference List find the icon file and number you wish to display and enter the appropriate value in the default key value box, in this case: %windir%\system32\shell32.dll,157  Now create another sub-key under your GUID key calles Shell and another sub-key below that one called Command Now as a value to the Default string within the Control key, enter the path to the .dll file you wish to run, in this case: "C:\Program Files (x86)\Microsoft Office\root\Office16\MLCFG32.CPL" |
The mail icon should be one of the defaults in: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Control Panel\Cpls\mail.cpl  If it is not appearing try importing this reg file: Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Control Panel\Cpls\mail.cpl] "RunLevel"=dword:00000000 @="\"C:\\Program Files (x86)\\Microsoft Office\\root\\Office16\\MLCFG32.CPL\"" |
Not on 64 bit Windows 10, it should be here: HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Control Panel\Cpls\ There should be a key called: mlcfg32.cplpointing to: C:\Program Files (x86)\Microsoft Office\root\Office16\MLCFG32.CPL  No quotes or it won't work. |
Windows Desktop
Windows 10
Important Information:
The Windows Server Forum uses cookies. By continuing to browse this site, you are agreeing to our use of cookies.
More Details
Close
