I am on Windows 10 Pro
Office 2019
I have NO control panel>mail icon
Even when I search or try and find any reference to 32-bit
My Office 2019 is 32bit
What can I do?
OK so just to say I looked for the file under the program files directory and it is still there:
"C:\Program Files (x86)\Microsoft Office\root\Office16\MLCFG32.CPL"
And if you double click it, you can still configure outlook 2019 OK
I will look into restoring it in the registry
If you go to this page:
https://www.microsoft.com/en-gb/p/guid-generator/9n79sdd9s9jj?activetab=pivot:overviewtab
You can download the control panel GUID creator from the Microsoft Store for Windows 8/10 +
Copy your generated GUID and open RedgEdit.exe as a computer administrator, as you will need to be able to make changes to HKEY_CLASSES_ROOT
Go to HKEY_CLASSES_ROOT\CLSID (Which is after all of the ones beginning with a period or full stop)
Right click on the CLSID key and choose NEW>Key and paste in the GUID from the GUID tool in these brackets {} :
Double click the 'Default' and in the value box, type the name of the Control Panel item as you wish it to appear.
Create another string in the same key called InfoTip and enter a useful tip for anyone using the item
Now click on the root key of your new item (the one you copied the GUID into) and create another key within it called DefaultIcon
Referencing Microsoft Windows Icon Reference List  find the icon file and number you wish to display and enter the appropriate value in the default key value box, in this case: %windir%\system32\shell32.dll,157
Now create another sub-key under your GUID key calles Shell and another sub-key below that one called Command
Now as a value to the Default string within the Control key, enter the path to the .dll file you wish to run, in this case: "C:\Program Files (x86)\Microsoft Office\root\Office16\MLCFG32.CPL"
The mail icon should be one of the defaults in:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Control Panel\Cpls\mail.cpl
If it is not appearing try importing this reg file:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Control Panel\Cpls\mail.cpl]
"RunLevel"=dword:00000000
@="\"C:\\Program Files (x86)\\Microsoft Office\\root\\Office16\\MLCFG32.CPL\""
Not on 64 bit Windows 10, it should be here:
HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Control Panel\Cpls\
There should be a key called: mlcfg32.cpl
pointing to:
No quotes or it won't work.
