#1 Posted : 23 June 2017 13:44:57(UTC)
I have got a Sage 2012 Accounts company set up on a network that everyone else is using quite happily.
I have a Windows 7 RT laptop that was using Sage 2009 before we upgraded.
I have upgraded the Windows 7 RT laptop.
Now when I point the laptop at the data it tells me:
'the path you have selected does not contain sage accounts data'
I have checked permissions and data paths and removed the company file from c:\programdata and started from the beginning again but still no joy.
Does anyone have any other suggestions?
Offline sirclesadmin
#2 Posted : 23 June 2017 13:47:01(UTC)
Rank: Administration
Groups: Administrators
Was thanked: 8 time(s) in 7 post(s)
This will be because the data is in a version that differs too greatly from the version you're using or you need to look in the correct place.
Either:
Upgrade with the correct Sage version disk first or download the update from sage manually.
Or
Find the company.001 or similar directory with the data inside. It should contain a folder called ACCData if the data is present and correct.g
Edited by user 27 November 2017 22:27:36(UTC)  | Reason: Not specified
#3 Posted : 28 May 2019 15:55:07(UTC)
The folder that Sage is looking for is the company folder which contains the ACCDATA folder. This is where the actual Sage data is held. If there is no ACCDATA folder containing SETUP.DTA ACCESS.DTA etc. as below:
Sage ACCDATA folder contents
Then you will receive the message 'the path you have selected does not contain sage accounts data'
The default location would usually be at c:\programdata\sage\accounts\
Sage Accounts ProgramData location
Under the appropriate year for the software version you are running, and then under the Company.000 folder or Company.001 if there are multiple companies etc.
If you cannot see a ACCDATA folder then try searching for it.
If you can find the ACCDATA folder but the system does not recognise the data, it could be that the SETUP.DAT or the ACCDATA.ini file is missing in which case you may need to restore from a backup, or if you need to keep the version you have, try restoring the old data elsewhere and copying the SETUP.DTA and ACCDATA.ini files over to repair the data you are using.
If you are still stuck, email sircles.net from their website for further advice or try their online chat.
Edited by user 28 May 2019 15:58:47(UTC)  | Reason: extra advice
