Help!
I have replaced an H700 that fizzed out
But the new one appears to be in direct mapping' mode which halts the system.
Perc H700 Attached enclosure doesn't support in controller's Direct mapping mode Please contact system support. System has halted due to unsupported configuration
I cannot get into the RAID config to turn it off - what can I do here?
So what we had to do was this:
We put the controller in a PC/workstation and booted it into Windows
We downloaded the CLI for the AVAGO megaraid from Dell
We ran the command: perccli /c0 disable directpdmapping=off where 0 is the adapter ID
Then after a reboot we ran: perccli /c0 show directpdmapping
 and got:
Controller = 0
Status = Success
Description = None
Controller Properties :
Ctrl_Prop       Value
Directpdmapping OFF
So now we'll try booting the system....
