I see a blue screen when trying to boot this machine - sometime it say machine service error and others WHEA uncorrectable error.
The WHEA_UNCORRECTABLE_ERROR (WUE) is a Windows stop code (0x00000124) that indicates a critical hardware error was detected by the Windows Hardware Error Architecture (WHEA). It's a type of blue screen of death (BSOD) that halts the operating system to prevent further damage.
What Causes a WHEA Uncorrectable Error?
This error typically stems from hardware-related problems. Common culprits include:
Hardware Issues
  • Failing CPU or overheating
  • Faulty RAM
  • Power supply instability
  • Overclocking instability
  • Motherboard problems
  • Corrupted storage (SSD/HDD)
  • PCIe devices like GPUs or expansion cards
Driver or Firmware Problems
  • Outdated chipset, BIOS, or firmware
  • Bad or misbehaving device drivers
Voltage and Thermal Issues
  • Undervolting or overvolting (especially on overclocked systems)
  • Inadequate cooling or bad thermal paste
Corrupted System Files
  • Files critical to boot or operation have become corrupt (less common)
How to Troubleshoot and Fix It
Here's a methodical approach:
1. Check Event Viewer or Dump Files
  • Look under Event Viewer > Windows Logs > System for critical error logs around the time of the crash.
  • Analyze the minidump files (C:\Windows\Minidump) using tools like BlueScreenView or WinDbg for specifics (e.g. CPU cache error, bus/interconnect issue).
2. Inspect Hardware Connections
  • Reseat:
    • RAM sticks
    • PCIe cards
    • CPU cooler
  • Ensure all power cables are seated and the power supply is stable.
3. Run Diagnostics
  • Memory test: mdsched.exe (Windows Memory Diagnostic) or MemTest86
  • Disk check: chkdsk /f /r or manufacturer SSD tools
  • CPU test: Use stress tools like Prime95 or OCCT (watch temps!)
4. Reset BIOS / UEFI Settings
  • Especially if you have overclocked CPU, RAM, or GPU.
  • Load Optimized Defaults in BIOS.
5. Update Drivers and BIOS
  • Update:
    • Chipset drivers
    • Storage drivers
    • BIOS/UEFI firmware
  • Use official motherboard and CPU manufacturer websites.
6. Check for Windows Corruption
  • sfc /scannow
  • DISM /Online /Cleanup-Image /RestoreHealth
7. Monitor Temperatures
Use HWMonitor, HWiNFO, or CoreTemp to check CPU/GPU temps under load. If you're hitting 90C+, that's a red flag.
8. Last Resort: Swap Components
  • Test with known-good RAM, GPU, or even a different PSU
  • Try a clean install of Windows on a spare disk to rule out OS issues
If You're on a Laptop
  • WUE can indicate:
    • Bad thermal paste
    • Dying cooling fan
    • Failing motherboard capacitor
  • Start with BIOS and driver updates, and make sure it's not overheating.
Forward-Thinking Tips
  • Don't overclock unless you fully understand voltage and thermal curves.
  • Enable automatic dump file saving (%SystemRoot%\MEMORY.DMP)
  • Keep a USB recovery stick ready.
  • Run stability tests after every major hardware/software change.
If you're repeatedly getting this error, you're being warned - your system is telling you something physical is going wrong. Unlike most software crashes, WHEA_UNCORRECTABLE_ERROR is not forgiving. Left unresolved, it can lead to permanent hardware damage or data loss.
