The WHEA_UNCORRECTABLE_ERROR (WUE) is a Windows stop code (0x00000124) that indicates a critical hardware error was detected by the Windows Hardware Error Architecture (WHEA). It's a type of blue screen of death (BSOD) that halts the operating system to prevent further damage.
What Causes a WHEA Uncorrectable Error?
This error typically stems from hardware-related problems. Common culprits include:
Hardware Issues
- Failing CPU or overheating
- Faulty RAM
- Power supply instability
- Overclocking instability
- Motherboard problems
- Corrupted storage (SSD/HDD)
- PCIe devices like GPUs or expansion cards
Driver or Firmware Problems
- Outdated chipset, BIOS, or firmware
- Bad or misbehaving device drivers
Voltage and Thermal Issues
- Undervolting or overvolting (especially on overclocked systems)
- Inadequate cooling or bad thermal paste
Corrupted System Files
- Files critical to boot or operation have become corrupt (less common)
How to Troubleshoot and Fix It
Here's a methodical approach:
1. Check Event Viewer or Dump Files
- Look under Event Viewer > Windows Logs > System for critical error logs around the time of the crash.
- Analyze the minidump files (
C:\Windows\Minidump
) using tools like BlueScreenView or WinDbg for specifics (e.g. CPU cache error, bus/interconnect issue).
2. Inspect Hardware Connections
3. Run Diagnostics
- Memory test:
mdsched.exe
(Windows Memory Diagnostic) or MemTest86
- Disk check:
chkdsk /f /r
or manufacturer SSD tools
- CPU test: Use stress tools like Prime95 or OCCT (watch temps!)
4. Reset BIOS / UEFI Settings
- Especially if you have overclocked CPU, RAM, or GPU.
- Load Optimized Defaults in BIOS.
5. Update Drivers and BIOS
6. Check for Windows Corruption
sfc /scannow
DISM /Online /Cleanup-Image /RestoreHealth
7. Monitor Temperatures
Use HWMonitor, HWiNFO, or CoreTemp to check CPU/GPU temps under load. If you're hitting 90C+, that's a red flag.
8. Last Resort: Swap Components
- Test with known-good RAM, GPU, or even a different PSU
- Try a clean install of Windows on a spare disk to rule out OS issues
If You're on a Laptop
Forward-Thinking Tips
- Don't overclock unless you fully understand voltage and thermal curves.
- Enable automatic dump file saving (
%SystemRoot%\MEMORY.DMP
- Keep a USB recovery stick ready.
- Run stability tests after every major hardware/software change.
If you're repeatedly getting this error, you're being warned - your system is telling you something physical is going wrong. Unlike most software crashes, WHEA_UNCORRECTABLE_ERROR is not forgiving. Left unresolved, it can lead to permanent hardware damage or data loss.
