PC & Mac Help and Assistance
Software and Accounting/CRM
Accounting Software
Starting Sage 200C database - the locale specific resource for the desired message is not present
Joined: 21/09/2020(UTC) Posts: 136  Location: Reading Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
SQL server for Sage 200C not starting the locale specific resource for the desired message is not present
OK, so far I have realised that the user logged in did not have access to the folders with the SQL DB and logs in.
Then I found that the user is an AD user that it runs under so need to connect to the DC.
Will report back if it still doesn't work.
Accounting Software
Important Information:
The PC & Mac Help and Assistance uses cookies. By continuing to browse this site, you are agreeing to our use of cookies.
More Details
Close
