  • andrewt2m
How can I find the application for this?
Log Name: System
Source: Microsoft-Windows-DistributedCOM
Date: 06/09/2023 12:16:56
Event ID: 10016
User: domain\%USERNAME%
Computer: RDServer.domain.local
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{8BC3F05E-D86B-11D0-A075-00C04FB68820}
and APPID
to the user domain\%USERNAME% SID (S-1-5-21-660087094-415256763-4027578020-1273) from address LocalHost (Using LRPC) running in the application container Unavailable SID (S-1-15-2-2034283098-2252572593-1075675386-2659511007-3245387615-27016815-3920691934). This security permission can be modified using the Component Services administrative tool.
    <Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
    <EventID Qualifiers="0">10016</EventID>
    <Keywords>0x8080000000000000</Keywords>
    <TimeCreated SystemTime="2023-09-06T11:16:56.875136300Z" />
    <EventRecordID>373972</EventRecordID>
    <Execution ProcessID="1500" ThreadID="44444" />
    <Channel>System</Channel>
    <Computer>RDServer.domain.local</Computer>
    <Security UserID="S-1-5-21-660054694-4152133463-4027578020-1273" />
    <Data Name="param1">application-specific</Data>
    <Data Name="param2">Local</Data>
    <Data Name="param3">Activation</Data>
    <Data Name="param4">{8BC3F05E-D86B-11D0-A075-00C04FB68820}</Data>
    <Data Name="param5">{8BC3F05E-D86B-11D0-A075-00C04FB68820}</Data>
    <Data Name="param6">domain</Data>
    <Data Name="param7">%USERNAME%</Data>
    <Data Name="param8">S-1-5-21-660087094-4152133463-4027578020-1273</Data>
    <Data Name="param9">LocalHost (Using LRPC)</Data>
    <Data Name="param10">Unavailable</Data>
    <Data Name="param11">S-1-15-2-2034283098-2252572593-1072577386-2659511007-3245387615-27016815-3920691934</Data>
  • andrewt2m
OK so the app appears to be 'Adobe Acrobat Reader Protected Mode' but was actually this:
 image.png You have insufficient rights to see the content.
What should the permissions really be to avoid these messages?
