Offline drdread
#1 Posted : 14 October 2020 14:29:41(UTC)
Australia
Was thanked: 2 time(s) in 2 post(s)
My Outlook which I just used to upload my PST file to Office 365 is now showing up many of the subfolders in the inbox as blank but states: Click here to view more on Microsoft Exchange instead of just showing the contents that I just uploaded.
If I click the Click here to view more on Microsoft Exchange text then the contents appear as fine.
Why is this? Should I just wait for it to repopulate the folder or should I just start a new Outlook profile and download the data afresh?
#2 Posted : 14 October 2020 14:42:38(UTC)
Was thanked: 5 time(s) in 5 post(s)
It just means that you have your Outlook set not to keep data as long in your cached file on the computer.
If you look on https://portal.office.com and open the web version of Outlook you will see everything.
If you go into Outlook and change the settings to keep all data (rather than 1 year or 3 days etc.) in your cached file, you will see everything in the folders once more.
This is done under File > Accounts Settings > Account Settings > Double click your email > Slide the slider all the way to the right.
Outlok data cache retention time dialogue box
Edited by user 14 October 2020 15:28:57(UTC)  | Reason: Not specified
