Joined: 08/01/2017(UTC) Posts: 743  Location: London Thanks: 22 times Was thanked: 12 time(s) in 10 post(s)
Hello Can I rename my External Network alias' in Hyper-V so that I am not just trying to remember which VLAN Microsoft Network Adapter Multiplexor Driver #3 is connected to? As below:  I would like to rename them all to coincide with the name of the VLANs I have attributed in Server Manager but cannot seem to find where they are named... Kind regards, Edited by user 02 October 2019 15:33:10(UTC)
| Reason: Not specified |
OK so I scanned the registry for where the NIC name would be and found it here:  HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\COMPOSITEBUS\MS_IMPLAT_MP\{NIC ID String} HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\vmsmp\parameters\NicList\/DEVICE/{NIC ID String} - you can only change this one as far as I can see, the other won't change I am going to try and relabel one that is not that important and see what happens.... :-o Edited by user 02 October 2019 16:22:13(UTC)
It doesn't appear you can change the first one on Windows 2016 - perhaps I need to be in safe mode or similar? Do I need to remove it from all VMs first? Edited by user 02 October 2019 16:22:23(UTC)
Important Information:
The PC & Mac Help and Assistance uses cookies. By continuing to browse this site, you are agreeing to our use of cookies.
More Details
Close
