#1 Posted : 05 September 2019 09:40:46(UTC)
We are seeing the following on a Windows 2012 R2 domain controller/global catalogue.
It is the only DC/GC in the domain.
Single domain with no children:
Log Name: System
Source: Schannel
Date: 05/09/2019 09:36:06
Event ID: 36886
Keywords:
User: SYSTEM
No suitable default server credential exists on this system. This will prevent server applications that expect to make use of the system default credentials from accepting SSL connections. An example of such an application is the directory server. Applications that manage their own credentials, such as the internet information server, are not affected by this.
<Provider Name="Schannel" Guid="{1F678132-5938-4686-9FDC-C8FF68F15C85}" />
<EventID>36886</EventID>
<TimeCreated SystemTime="2019-09-05T08:36:06.866420400Z" />
<EventRecordID>354207</EventRecordID>
<Execution ProcessID="584" ThreadID="6308" />
<Channel>System</Channel>
<Computer>%computername%.domain.local</Computer>
Any ideas?
