#1 Posted : 24 August 2018 08:44:08(UTC)
Was thanked: 12 time(s) in 10 post(s)
What is the process for administering CentOS on Hyper-V 2016 onwards - is there a Linux installation of Integration Services?
Currently we are seeing:
Log Name: Microsoft-Windows-Hyper-V-Integration-Admin
Source: Microsoft-Windows-Hyper-V-Integration-KvpExchange
Date: 15/08/2018 08:57:44
Event ID: 4096
Keywords:
User: NT VIRTUAL MACHINE\A6645A11-1202-4D78-B5A7-90780E2FED89
Computer: %COMPUTERNAME%.domain.suffix
'VMNAME': The Data Exchange integration service is either not enabled, not running or not initialized. (Virtual machine ID A6645A11-1202-4D78-B5A7-90780E2FED89)
<Provider Name="Microsoft-Windows-Hyper-V-Integration-KvpExchange" Guid="{82D60869-5ADA-4D49-B76A-309B09666584}" />
<EventID>4096</EventID>
<TimeCreated SystemTime="2018-08-15T07:57:44.859982300Z" />
<EventRecordID>2141</EventRecordID>
<Correlation ActivityID="{73901FDD-7AE3-0012-EEDC-C4C4900ED401}" />
<Execution ProcessID="5628" ThreadID="6520" />
<Channel>Microsoft-Windows-Hyper-V-Integration-Admin</Channel>
<Computer>%COMPUTERNAME%.domain.suffix</Computer>
<Security UserID="USERID" />
<UserData>
<VmlEventLog xmlns:auto-ns2="http://schemas.microsoft.com/win/2004/08/events" xmlns="http://www.microsoft.com/Windows/Virtualization/Events">
<VmName>VMNAME</VmName>
<VmId>A6645A11-1202-4D78-B5A7-90780E2FED89</VmId>
<Param1>
</Param1>
<Param2>
</Param2>
<Param3>
</Param3>
</VmlEventLog>
</UserData>
or PayPal with This Link
#2 Posted : 24 August 2018 08:50:21(UTC)
Also seeing this, which I presume is the same issue - is there a version that has been installed as part of the install process?
Date: 15/08/2018 08:50:57
Event ID: 4010
Keywords:
Computer: VMHOSTNAME.domain.suffix
Hyper-V Data Exchange connected to virtual machine 'CentOS', but the version does not match the version expected by Hyper-V (Virtual machine ID A6645A11-1202-4D78-B5A7-90780E2FED89). Framework version: Negotiated (3.0) - Expected (3.0); Message version: Negotiated (4.0) - Expected (5.0). This is an unsupported configuration. This means that technical support will not be provided until this problem is resolved. To fix this problem, upgrade the integration services. To upgrade, connect to the virtual machine and select Insert Integration Services Setup Disk from the Action menu.
<Provider Name="Microsoft-Windows-Hyper-V-Integration-KvpExchange" Guid="{ID}" />
<EventID>4010</EventID>
<TimeCreated SystemTime="2018-08-15T07:50:57.811561900Z" />
<EventRecordID>2136</EventRecordID>
<Execution ProcessID="5628" ThreadID="5996" />
<Computer>VMHOSTNAME.domain.suffix</Computer>
<Security UserID="ID" />
<UserData>
<VmName>CentOS</VmName>
<Param1>Negotiated (3.0) - Expected (3.0)</Param1>
<Param2>Negotiated (4.0) - Expected (5.0)</Param2>
<Param3>
</Param3>
</VmlEventLog>
</UserData>
#3 Posted : 24 August 2018 08:51:26(UTC)
Device 'Microsoft Synthetic Display Controller' in 'CentOS' is loaded but has a different version from the server. Server version 3.3 Client version 3.2 (Virtual machine ID). The device will work, but this is an unsupported configuration. This means that technical support will not be provided until this problem is resolved. To fix this problem, upgrade the integration services. To upgrade, connect to the virtual machine and select Insert Integration Services Setup Disk from the Action menu.
#4 Posted : 24 August 2018 08:55:34(UTC)
#5 Posted : 10 March 2020 08:18:50(UTC)
The Linux integration software has stopped this message appearing and allows for most of the normal Hyper-v features such as shutdown and time sync., so it is definitely worth installing on your Centos 7 Hyper-V hosted boxes.
Trustpilot
