Does it use the same servers as the main GPT4? It is a custom ChatGPT.
Given that 'TopOnGoogle' is a custom implementation of ChatGPT provided by OpenAI, it still operates on the same underlying infrastructure but might have specific configurations or customizations affecting its performance. Here are a few more focused steps to troubleshoot and potentially improve its responsiveness:
Check OpenAI's Status Page: Visit the OpenAI Status Page to see if there are any ongoing incidents or maintenance activities affecting performance.
Rate Limits and Quotas: Ensure that 'TopOnGoogle' is not hitting any rate limits or quotas imposed by OpenAI's API. You might need to upgrade your plan or request higher limits if usage is high.
Optimize API Calls: If you have control over the implementation, review how the API calls are made. Batch processing or optimizing the payload can sometimes improve response times.
Caching Responses: Implementing a caching mechanism for common queries can reduce the load and improve perceived performance.
Load Balancing: If 'TopOnGoogle' handles a high volume of requests, ensuring proper load balancing across multiple instances can help maintain performance.
Local System Performance: Make sure the device you are using has sufficient resources (CPU, RAM) to handle the application smoothly.
Browser Optimization: Clear cache and cookies, or try using a different browser to see if there is any improvement.
Contact Support: Reach out to 'TopOnGoogle' support for specific advice related to their custom implementation. They might provide insights or optimizations specific to their setup.
If the performance issues persist, detailing the exact nature of the delays (e.g., specific operations or times of day) can help in diagnosing and addressing the problem more effectively.
Edited by user
