2 months ago
blogengine.net using SQL - error after DB prep and install:
Source: ASP.NET 4.0.30319.0
Date: 04/10/2023 08:04:12
Event ID: 1310
Task Category: Web Event
Computer: PC.domain.local
Event code: 3008
Event message: A configuration error has occurred.
Event time: 04/10/2023 08:04:12
Event time (UTC): 04/10/2023 07:04:12
Event ID: 9775c049450a435e914ea1d29065c854
Event sequence: 14
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/44/ROOT-8-133408764654873095
Trust level: Full
Application Virtual Path: /
Application Path: E:\Websites\www\site\
Machine name: PC
Process information:
Process ID: 7248
Process name: w3wp.exe
Account name: IIS APPPOOL\site
Exception information:
Exception type: ConfigurationErrorsException
Exception message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (E:\Websites\www\site\blog\web.config line 10)
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
at System.Configuration.BaseConfigurationRecord.GetSection(String configKey)
at System.Web.Configuration.RuntimeConfig.GetSectionObject(String sectionName)
at System.Web.Configuration.RuntimeConfig.GetSection(String sectionName, Type type, ResultsIndex index)
at System.Web.Configuration.RuntimeConfig.get_Identity()
at System.Web.HttpContext.SetImpersonationEnabled()
at System.Web.HttpApplication.AssignContext(HttpContext context)
at System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context)
Request information:
Request URL: https://weburl:443/blog
Request path: /blog
User host address: x.x.x.x
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\site
Thread information:
Thread ID: 21
Is impersonating: False
Stack trace: at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
Custom event details:
    <Provider Name="ASP.NET 4.0.30319.0" />
    <EventID Qualifiers="32768">1310</EventID>
    <Task>3</Task>
    <TimeCreated SystemTime="2023-10-04T07:04:12.000000000Z" />
    <EventRecordID>3050612</EventRecordID>
    <Computer>PC.domain.local</Computer>
    <Data>3008</Data>
    <Data>A configuration error has occurred.</Data>
    <Data>04/10/2023 08:04:12</Data>
    <Data>04/10/2023 07:04:12</Data>
    <Data>9775c049450a435e914ea1d29065c854</Data>
    <Data>14</Data>
    <Data>1</Data>
    <Data>0</Data>
    <Data>/LM/W3SVC/44/ROOT-8-133408764654873095</Data>
    <Data>Full</Data>
    <Data>/</Data>
    <Data>E:\Websites\www\site\</Data>
    <Data>PC</Data>
    <Data>
    <Data>7248</Data>
    <Data>w3wp.exe</Data>
    <Data>IIS APPPOOL\site</Data>
    <Data>ConfigurationErrorsException</Data>
    <Data>It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level.  This error can be caused by a virtual directory not being configured as an application in IIS. (E:\Websites\www\site\blog\web.config line 10)
   at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object&amp; result, Object&amp; resultRuntimeObject)
    <Data>https://weburl:443/blog</Data>
    <Data>/blog</Data>
    <Data>31.121.141.175</Data>
    <Data>
    <Data>False</Data>
    <Data>
    <Data>21</Data>
    <Data>False</Data>
    <Data>   at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
Want to thank us? Use: Patreon or PayPal or Bitcoins: 3GJia7gLLY8V8eYBf5Q3RjCrNV8kZC3aNn
