What does this mean?
Log Name: Microsoft-Windows-Kernel-PnP/Configuration
Source: Microsoft-Windows-Kernel-PnP
Date: 21/04/2023 20:36:02
Event ID: 442
Keywords:
User: SYSTEM
Device settings for PCI\VEN_1077&DEV_8020&SUBSYS_3733103C&REV_54\4&2907294e&0&0048 were not migrated from previous OS installation due to partial or ambiguous device match.
Last Device Instance Id: SWD\IP_TUNNEL_VBUS\ISATAP_0
Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FFFFFFFFF132
Present: true
Status: 0xC0000719
<Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9c205a39-1250-487d-abd7-e831c6290539}" />
<EventID>442</EventID>
<Keywords>0x4000000000000000</Keywords>
<TimeCreated SystemTime="2023-04-21T19:36:02.7496207Z" />
<EventRecordID>2355</EventRecordID>
<Execution ProcessID="4" ThreadID="912" />
<Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
<Computer>%computername%.domain.local</Computer>
<Data Name="DeviceInstanceId">PCI\VEN_1077&DEV_8020&SUBSYS_3733103C&REV_54\4&2907294e&0&0048</Data>
<Data Name="LastDeviceInstanceId">SWD\IP_TUNNEL_VBUS\ISATAP_0</Data>
<Data Name="ClassGuid">{4d36e972-e325-11ce-bfc1-08002be10318}</Data>
<Data Name="LocationPath">
<Data Name="MigrationRank">0xf000fffffffff132</Data>
<Data Name="Present">true</Data>
<Data Name="Status">0xc0000719</Data>
