What does this mean?
Log Name:      Microsoft-Windows-Kernel-PnP/Configuration
Source:        Microsoft-Windows-Kernel-PnP
Date:          21/04/2023 20:36:02
Event ID:      442
Level:         Warning
Keywords:
User:          SYSTEM
Computer:      %computername%.domain.local
Device settings for PCI\VEN_1077&DEV_8020&SUBSYS_3733103C&REV_54\4&2907294e&0&0048 were not migrated from previous OS installation due to partial or ambiguous device match.
Last Device Instance Id: SWD\IP_TUNNEL_VBUS\ISATAP_0
Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FFFFFFFFF132
Present: true
Status: 0xC0000719
    <Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9c205a39-1250-487d-abd7-e831c6290539}" />
    <EventID>442</EventID>
    <Keywords>0x4000000000000000</Keywords>
    <TimeCreated SystemTime="2023-04-21T19:36:02.7496207Z" />
    <EventRecordID>2355</EventRecordID>
    <Execution ProcessID="4" ThreadID="912" />
    <Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
    <Computer>%computername%.domain.local</Computer>
    <Data Name="DeviceInstanceId">PCI\VEN_1077&amp;DEV_8020&amp;SUBSYS_3733103C&amp;REV_54\4&amp;2907294e&amp;0&amp;0048</Data>
    <Data Name="LastDeviceInstanceId">SWD\IP_TUNNEL_VBUS\ISATAP_0</Data>
    <Data Name="ClassGuid">{4d36e972-e325-11ce-bfc1-08002be10318}</Data>
    <Data Name="LocationPath">
    <Data Name="MigrationRank">0xf000fffffffff132</Data>
    <Data Name="Present">true</Data>
    <Data Name="Status">0xc0000719</Data>
