herbet
  • herbet
  • 91% (Exalted)
3 months ago
I am trying to repair a DB in a suspect state after exporting a VM server.
I have backups from the other day but I would rather use the live one.
It is not a production system.
What is this error on DBCC checker running?
Msg 596, Level 21, State 1, Line 0
Cannot continue the execution because the session is in the kill state.
Msg 0, Level 20, State 0, Line 0
A severe error occurred on the current command.  The results, if any, should be discarded.
herbet
  • herbet
  • 91% (Exalted)
3 months ago
I had to put the DB in single user mode:
ALTER DATABASE [DB Name]  SET SINGLE_USER WITH ROLLBACK IMMEDIATE
GO
run the checker with:
DBCC CHECKDB (B[DB Name] REPAIR_ALLOW_DATA_LOSS)
GO
Then run the checker again:
DBCC CHECKDB
GO
Then put it back in multi user mode:
ALTER DATABASE [DB Name] SET MULTI_USER
GO
After that it seemed to be OK
herbet
  • herbet
  • 91% (Exalted)
3 months ago
Just as a sidenote - this was from running Disk2VHD on an SQL server with transaction shipping installed which is what caused the issue.
I also had to restore the master and msdb DBs to get it working and restore file permissions to the DB files afterwards.
