Source: ASP.NET 4.0.30319.0
Date: 30/07/2023 16:18:49
Event ID: 1309
Task Category: Web Event
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 30/07/2023 16:18:49
Event time (UTC): 30/07/2023 15:18:49
Event ID: ddd7188e3eb244c38057e01c207e0d25
Event sequence: 1
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT-19-133352039294690423
Trust level: Full
Application Virtual Path: /
Application Path: E:\Websites\www\blog.domain.local.sql\
Machine name: %computername%
Process information:
Process ID: 7392
Process name: w3wp.exe
Account name: IIS APPPOOL\Blog SQL
Exception information:
Exception type: TargetInvocationException
Exception message: Exception has been thrown by the target of an invocation.
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture)
at System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args)
at System.Web.HttpApplication.BuildIntegratedModuleCollection(List`1 moduleList)
at System.Web.HttpApplication.GetModuleCollection(IntPtr appContext)
at System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers)
at System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context)
at System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context)
at System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext)
The type initializer for 'BlogEngine.Core.Right' threw an exception.
at BlogEngine.Core.Right..ctor()
Login failed for user 'SIRCLES\%computername%$'.
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, SqlCredential credential, Object providerInfo, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance, SqlConnectionString userConnectionOptions, SessionData reconnectSessionData, DbConnectionPool pool, String accessToken, Boolean applyTransientFaultHandling, SqlAuthenticationProviderManager sqlAuthProviderManager)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnectionPool pool, DbConnection owningObject, DbConnectionOptions options, DbConnectionPoolKey poolKey, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject, DbConnectionOptions userOptions, DbConnectionInternal oldConnection)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject, DbConnectionOptions userOptions, DbConnectionInternal oldConnection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.SqlClient.SqlConnection.TryOpenInner(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.Open()
at BlogEngine.Core.Providers.DbConnectionHelper..ctor(String providerName, String connectionString) in C:\rtur\src\github\BlogEngine.NET\BlogEngine\BlogEngine.Core\Providers\DbProvider\DbConnectionHelper.cs:line 60
at BlogEngine.Core.Providers.DbBlogProvider.CreateConnection() in C:\rtur\src\github\BlogEngine.NET\BlogEngine\BlogEngine.Core\Providers\DbProvider\DbBlogProvider.cs:line 3028
at BlogEngine.Core.Providers.DbBlogProvider.FillBlogs() in C:\rtur\src\github\BlogEngine.NET\BlogEngine\BlogEngine.Core\Providers\DbProvider\DbBlogProvider.cs:line 121
at BlogEngine.Core.Blog.get_Blogs() in C:\rtur\src\github\BlogEngine.NET\BlogEngine\BlogEngine.Core\Blog.cs:line 395
at BlogEngine.Core.Blog.get_CurrentInstance() in C:\rtur\src\github\BlogEngine.NET\BlogEngine\BlogEngine.Core\Blog.cs:line 472
at BlogEngine.Core.Right.EnsureBlogInstanceDataLoaded() in C:\rtur\src\github\BlogEngine.NET\BlogEngine\BlogEngine.Core\Services\Security\Right.cs:line 547
at BlogEngine.Core.Right..cctor() in C:\rtur\src\github\BlogEngine.NET\BlogEngine\BlogEngine.Core\Services\Security\Right.cs:line 113
Request information:
Request URL: http://%computername%.domain.local/
Request path: /
User host address: fe80::f53c:5db1:7ba3:90cf1
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\Blog SQL
Thread information:
Thread ID: 116
Is impersonating: False
Stack trace: at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
Custom event details:
<Provider Name="ASP.NET 4.0.30319.0" />
<EventID Qualifiers="32768">1309</EventID>
<Task>3</Task>
<TimeCreated SystemTime="2023-07-30T15:18:49.7989358Z" />
<EventRecordID>1458</EventRecordID>
<Computer>%computername%.domain.local</Computer>
<Data>3005</Data>
<Data>An unhandled exception has occurred.</Data>
<Data>30/07/2023 16:18:49</Data>
<Data>30/07/2023 15:18:49</Data>
<Data>ddd7188e3eb244c38057e01c207e0d25</Data>
<Data>1</Data>
<Data>1</Data>
<Data>0</Data>
<Data>/LM/W3SVC/1/ROOT-19-133352039294690423</Data>
<Data>Full</Data>
<Data>/</Data>
<Data>E:\Websites\www\blog.domain.local.sql\</Data>
<Data>%computername%</Data>
<Data>
<Data>7392</Data>
<Data>w3wp.exe</Data>
<Data>IIS APPPOOL\Blog SQL</Data>
<Data>TargetInvocationException</Data>
<Data>Exception has been thrown by the target of an invocation.
<Data>http://%computername%.domain.local/</Data>
<Data>/</Data>
<Data>fe80::f53c:5db1:7ba3:90cf%7</Data>
<Data>
<Data>False</Data>
<Data>
<Data>116</Data>
<Data>False</Data>
<Data> at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
Edited by user
