Is this a problem with my SATA controller or does it mean that the disk is faulty?
Source: Microsoft-Windows-Defrag
Date: 31/01/2023 10:58:49
Event ID: 264
Computer: PC.domain.local
The storage optimizer couldn't complete retrim on Exports (D:) because: The operation requested is not supported by the hardware backing the volume. (0x8900002A)
<Provider Name="Microsoft-Windows-Defrag" />
<EventID Qualifiers="32768">264</EventID>
<TimeCreated SystemTime="2023-01-31T10:58:49.9383474Z" />
<EventRecordID>77300</EventRecordID>
<Computer>PC.domain.local</Computer>
<Data>retrim</Data>
<Data>Exports (D:)</Data>
<Data>The operation requested is not supported by the hardware backing the volume. (0x8900002A)</Data>
<Binary>2A000089800200008D0000009000000022B63823DBB1BD381B0700000000000000000000</Binary>
Edited by user
