JustinKing
Can anyone explain what is causing this?
Log Name:      Application
Source:        ESENT
Date:          31/01/2023 12:01:49
Event ID:      623
Task Category: Transaction Manager
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      PC.domain.local
SearchIndexer (16908,D,23) Windows: The version store for this instance (0) has reached its maximum size of 128Mb. It is likely that a long-running transaction is preventing cleanup of the version store and causing it to build up in size. Updates will be rejected until the long-running transaction has been completely committed or rolled back.
Possible long-running transaction:
    SessionId: 0x00000146F60B10C0:0x3be4a4
    Session-context: 0x00000000
    Session-context ThreadId: 0x000000000000120C
    Cleanup: 1
    Session-trace:
45861@12:01:49
57573@12:01:44
    <Provider Name="ESENT" />
    <EventID Qualifiers="0">623</EventID>
    <Task>14</Task>
    <TimeCreated SystemTime="2023-01-31T12:01:49.6771228Z" />
    <EventRecordID>77306</EventRecordID>
    <Computer>PC.domain.local</Computer>
    <Data>SearchIndexer</Data>
    <Data>16908,D,23</Data>
    <Data>Windows: </Data>
    <Data>0</Data>
    <Data>128</Data>
    <Data>0x00000146F60B10C0:0x3be4a4</Data>
    <Data>0x00000000</Data>
    <Data>0x000000000000120C</Data>
    <Data>1</Data>
    <Data>45861@12:01:49
57573@12:01:44
