5 months ago
What does this mean - seeing on all drives:
Source: Microsoft-Windows-Defrag
Date: 24/03/2025 03:20:54
Event ID: 257
Computer: TEDDC1.TED.local
The volume (C:) was not optimized because an error was encountered: Neither Slab Consolidation nor Slab Analysis will run if slabs are less than 8 MB. (0x8900002D)
    <Provider Name="Microsoft-Windows-Defrag" />
    <EventID Qualifiers="32768">257</EventID>
    <TimeCreated SystemTime="2025-03-24T03:20:54.000000000Z" />
    <EventRecordID>1200508</EventRecordID>
    <Computer>TEDDC1.TED.local</Computer>
    <Data>(C:)</Data>
    <Data>Neither Slab Consolidation nor Slab Analysis will run if slabs are less than 8 MB. (0x8900002D)</Data>
    <Binary>2D0000896303000094010000AE0100002236B942D9B1BD381B0700000000000000000000</Binary>
5 months ago
That message:
"The volume Folders and Data (F:) was not optimized because an error was encountered: Neither Slab Consolidation nor Slab Analysis will run if slabs are less than 8 MB. (0x8900002D)"
is coming from Windows' defragmentation/optimization tool, and it's telling you something specific and mostly harmless.
🔍 What it actually means:
  • "Slabs" refer to data segments in thinly provisioned volumes or Storage Spaces—they're virtual disk segments that Windows uses to manage disk usage.
  • The error 0x8900002D means that the defragmentation (optimization) process was skipped because the individual "slabs" of data are smaller than 8 MB.
  • Windows’ optimizer requires slabs to be at least 8 MB to perform consolidation or analysis.
  • So basically: nothing is wrong, it just couldn't do anything useful on that volume, probably because it's either nearly empty, or it’s not a traditional HDD, or it’s a virtual/dynamic disk that doesn't need traditional defrag-style optimization.
đź’ˇ In Plain Terms:
“I tried to optimize this drive, but I couldn’t do anything because all the little data chunks are already small — too small to optimize.”
đź›  What You Should Do:
  • No action needed, unless you’re experiencing performance issues (which is unlikely due to this).
  • If you're optimizing SSDs, know that traditional defragmentation is not necessary, and Windows already does "trim" operations for SSDs automatically.
  • If this is a network drive, virtual disk, external USB, or a thin-provisioned Storage Space, this message is normal and nothing to worry about.
đź§  Future Considerations:
  • If you’re scripting or automating optimization tasks and seeing these logs/errors, you might want to filter out or ignore 0x8900002D in your logs—it’s an informative code, not a warning or critical error.
Want help checking if your disk type or setup makes this expected? Or want a script to skip drives that can't be optimized?
