Have downloaded a new version of a website that points to an SQL server but when we try to run we get an error:
Server Error in '/' Application.
Could not load file or assembly 'Newtonsoft.Json, Version=6.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=6.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'Newtonsoft.Json, Version=6.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=6.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)]
   System.Net.Http.Formatting.BaseJsonMediaTypeFormatter..ctor() +0
   System.Net.Http.Formatting.JsonMediaTypeFormatter..ctor() +73
   System.Net.Http.Formatting.MediaTypeFormatterCollection.CreateDefaultFormatters() +55
   System.Web.Http.HttpConfiguration.DefaultFormatters(HttpConfiguration config) +34
   System.Web.Http.HttpConfiguration..ctor(HttpRouteCollection routes) +388
   System.Web.Http.c.b__11_0() +94
   System.Lazy`1.CreateValue() +734
   System.Lazy`1.LazyInitValue() +189
   System.Web.Http.GlobalConfiguration.Configure(Action`1 configurationCallback) +53
   YAF.Core.Context.YafHttpApplication.Application_Start(Object sender, EventArgs e) +107
[HttpException (0x80004005): Could not load file or assembly 'Newtonsoft.Json, Version=6.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)]
   System.Web.HttpApplicationFactory.EnsureAppStartCalledForIntegratedMode(HttpContext context, HttpApplication app) +546
   System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +171
   System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +173
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +255
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +347
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +552
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +122
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +737
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.8.4494.0
