7 months ago
Errors during daily VSS:
Quote:
Log Name:      Application
Source:        VSS
Date:          13/08/2022 21:04:08
Event ID:      22
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      IIS.domain.local
Volume Shadow Copy Service error: A critical component required by the Volume Shadow Copy service is not registered. This might happened if an error occurred during Windows setup or during installation of a Shadow Copy provider. The error returned from CoCreateInstance on class with CLSID {3e02620c-e180-44f3-b154-2473646e4cb8} and Name SW_PROV is [0x80040154, Class not registered
Operation:
   Obtain a callable interface for this provider
   List interfaces for all providers supporting this context
   Delete Shadow Copies
Context:
   Provider ID: {74600e39-7dc5-4567-a03b-f091d6c7b092}
   Class ID: {3e02620c-e180-44f3-b154-2473646e4cb8}
   Snapshot Context: -1
   Execution Context: Coordinator
    2724384
    IIS.domain.local
    SW_PROV
Operation:
Context:
    2D20436F64653A20434F52534F46544330303030303038302D2043616C6C3A20434F52534F46544330303030303036352D205049443A202030303030393332342D205449443A202030303030383737362D20434D443A2020433A5C57696E646F77735C73797374656D33325C76737376632E6578652020202D20557365723A204E616D653A204E5420415554484F524954595C53595354454D2C205349443A532D312D352D313820
Source:        VSS
Date:          13/08/2022 21:04:07
Event ID:      12292
Level:         Error
Keywords:      Classic
User:          N/A
Volume Shadow Copy Service error: Error creating the Shadow Copy Provider COM class with CLSID {3e02620c-e180-44f3-b154-2473646e4cb8} [0x80040154, Class not registered
Operation:
   Get Shadow Copy Properties
Context:
    12292
    2724383
    IIS.domain.local
Operation:
Context:
    2D20436F64653A20434F52534F46544330303030303038372D2043616C6C3A20434F52534F46544330303030303036352D205049443A202030303030393332342D205449443A202030303030383737362D20434D443A2020433A5C57696E646F77735C73797374656D33325C76737376632E6578652020202D20557365723A204E616D653A204E5420415554484F524954595C53595354454D2C205349443A532D312D352D313820
