8 years ago
I am trying to connect remotely over HTTPS to my DrayTek router but I just get 'page cannot be displayed' when this has always worked historically. Has anyone got any suggestions?
SOLUTION - Hello and thank-you for posting to the forum
This is because Microsoft Edge no longer supports SSL 1-3 by default. Either try upgrading the firmware of the router to see if you can use TLS instead (best option) or use Internet Explorer.
We would not recommend enabling SSL 2&3 on Microsoft Edge as this protocol has weaknesses and could be compromised to discover your router passwords.
