23 days ago
AD seems to have orphaned info about the public folders: Process w3wp.exe (FE_Mapi) (PID=12148). Object [CN=Mailbox Database 097409384905,CN=Databases,CN=Exchange Administrative Group (FYDIBOHF23SPDLT),CN=Administrative Groups,CN=DomainHQ,CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=domain,DC=local]. Property [PublicFolderDatabase] is set to value [argofield.local/Configuration/Deleted Objects/Public Folders
DEL:6546584a90-efcc-4f9d-a2db-16cb212321559], it is pointing to the Deleted Objects container in Active Directory. This property should be fixed as soon as possible.
23 days ago
Ah yes - that one's a classic Exchange/AD migration ghost. What you're seeing is an orphaned reference to a deleted Public Folder database, still hanging around in the AD configuration container.
The Problem
You're getting:
Object ... Property [PublicFolderDatabase] is set to value [...] Deleted Objects [...] This property should be fixed as soon as possible.
This means that some mailbox databases (or other Exchange objects) still have a reference to a Public Folder database that was deleted, and AD is now pointing to it in the Deleted Objects container.
This is a harmless but noisy issue - until you try something that expects a clean AD config, such as:
  • Installing a new CU
  • Adding/removing mailbox databases
  • Migrating to modern public folders
  • Decommissioning the last 2013 server
What To Do: Clean the Orphaned PublicFolderDatabase Property
You need to clear that attribute manually in AD using ADSIEDIT.
Step-by-Step Fix (ADSIEDIT)
Be cautious in ADSIEDIT - changes are instant and permanent.
1. Open ADSI Edit
  • Run adsiedit.msc
  • Connect to Configuration context
2. Navigate to the Mailbox Database object
Go to:
CN=Configuration [DC...]
CN=Services
CN=Argofield HQ
CN=Databases
CN=Mailbox Database 0655979533
3. Right-click Properties
  • Find the attribute: msExchHomePublicMDB
  • You'll likely see it set to something like:
    CN=Public Folders\0ADEL:34584a90-efcc-4f9d-a2db-16cb21312559,CN=Deleted Objects,...
4. Clear it
  • Select the attribute
  • Click Clear
  • Click OK to apply
5. Close ADSIEDIT and wait for replication
This removes the broken reference to the old PF database.
Optional: Check All Databases
You can scan all mailbox databases for stale PF links via PowerShell:
Get-MailboxDatabase | Select Name,PublicFolderDatabase
If any of them are populated, you can clear them with:
Set-MailboxDatabase "Mailbox Database 0655979533" -PublicFolderDatabase $null
Note: This only works if PublicFolderDatabase was still valid in Exchange - if it's already pointing to a deleted object, you must use ADSIEDIT.
Summary
StepAction
1Open ADSIEDIT and connect to Configuration context
2Browse to CN=Mailbox Database 0655979533
3Clear msExchHomePublicMDB
4Confirm and exit
5Let replication settle and confirm error disappears from event log
Let me know if you want a script to scan for and report on all such broken PF links across all databases.
