Fantastic! That's excellent news. Pinpointing the issue to the theme is a huge step forward.
Since it works with other themes, we can now focus our efforts directly on your current theme. This means the problem is either:
- A bug in the theme itself: Something in its code (especially its JavaScript or how it handles queries for the posts page) is conflicting with Chrome when you're logged out.
- A conflict between your theme and a plugin: Less likely if the issue disappears with any other theme, but still possible.
- Specific theme options: Your theme might have built-in performance or optimization settings that are causing the issue.
Here's the plan to resolve it now that we know it's the theme:
1. Update the Theme:
* First and foremost, check if there's an update available for your theme. Theme developers often release updates to fix bugs, improve compatibility, and add new features.
* Go to Appearance
> Themes
in your WordPress admin. If an update is available, you'll usually see a notification.
* Backup your site before updating (especially if it's a major theme update or a custom theme).
2. Check Theme's Built-in Optimization/Performance Settings:
Many modern themes include their own performance features (e.g., lazy loading, deferring JavaScript, minifying CSS, built-in caching).
* Look for a dedicated "Theme Options," "Theme Settings," or "Performance" panel within your theme's settings in the WordPress admin.
* Systematically disable any optimization, performance, or script-related settings one by one, testing the "Posts" page in Chrome (logged out, incognito window is best for testing) after each change.
* Common culprits:
* JavaScript deferral/async loading
* CSS minification/combination
* Lazy loading for images/videos
* Google Fonts optimization
* Built-in caching features
3. Contact the Theme Developer:
If updating and checking theme settings doesn't resolve it, this is your next best step.
* Provide them with detailed information:
* Explain that the "Posts" page does not load in Chrome when logged out, but works fine in Edge and also works fine in Chrome when logged in.
* Mention that it works correctly when you switch to a default WordPress theme.
* Provide any error messages you saw in Chrome's Developer Console (Console and Network tabs) if you managed to capture them.
* They might have a known bug, a specific setting recommendation, or a fix in the works.
4. Temporary Plugin Deactivation (If needed after theme settings):
While less likely since it works with other themes, there's a slim chance your active theme might have a specific conflict with one of your plugins that only manifests in Chrome when logged out.
* Deactivate all plugins (except the theme-required ones, if any).
* Test the "Posts" page in Chrome (logged out).
* If it works, reactivate plugins one by one until the issue reappears, then you'll know which plugin specifically conflicts with your theme.
5. Consider Theme Alternatives (Last Resort):
If the theme developer can't provide a solution, and you've exhausted all other options, you might need to consider switching to a different, more actively supported, or better-coded theme that is compatible with modern browsers.
Your Immediate Next Step:
- Update your theme.
- Check and systematically disable your theme's built-in optimization/performance settings.
Let's hope an update or a specific theme setting resolves it!
