Trying to import PST files exported from Exchange Server 2016, I am receiving the message:
some items cannot be copied, they were either moved or deleted, or access was denied.
But the items are there in the PST because I can see them.
It seems to get a little closer to completing with each attempted import, but I don't remember it ever being this unreliable before.
holtzerhutchings
Users can import PST into Office 365 in several ways; The best way to do this will be what they need. Technically savvy users can manually import their PST files into Office 365 but this method has many drawbacks such as data loss, file size limitation, cumbersome steps, and time-consuming resources they bring into process so most users do not recommend this method the help of the application, users can use a reliable application that ranks three like Softaken Mail Importer Software have been used to import their local files to Cloud-based email clients like Hotmail, Gmail, G Suite, AOL etc. Also, this application is so simple without any technical knowledge Users can use this program on their operating system. All versions of Microsoft Windows including 11, 10, 8.1, 8, 7, XP, Vista, and all versions listed below are compatible with this advanced software. It also offers a free trial of this utility to learn more about this user-friendly system.
What a load of nonsense. There is no data loss when importing PST into Microsoft 365. I do it pretty much daily. The process is simple and highly reliable even if you have to restart the operation a few times, just make sure you choose not to import duplicate items. The thing to rememebr about all these people trying to sell expensive software to do it for you is that they just use the same MS library to do the same job anyway and so it doesn't make any difference at all!
macwicarter
You may also use MacMister PST Converter solution to import PST files into Office 365 directly with all emails and attachments. The application is easy to use, simple, and advanced. Both technical and non-technical users can also utilize the software and perform the migration of PST files with ease. Its features are also remarkable with the help of users may import PST to Office 365 on Mac according to the requirements. However, besides Office 365, the tool has 15+ more saving options in which users can import PST files. Download the software free demo to check how to import PST files to Office 365 for free.
OK but what makes it any better than just using Outlook or any other tool, apart from the 'free demo until you need to actually import something' feature?
christinetwitty
2 months ago
Transferring PST files to Office 365 may be a challenging task, particularly when the amount of data is huge. Although Outlook can be used in a simple way, it is not very suitable for mass transfers. It is simplified using a PST converter tool that enables you to preview and filter PST files while importing them directly into Office 365 without losing their emails and attachments as well as their folder structure. To make the process much easier, resort to a well-known tool, such as BLR Tools.
Lennox Luna
11 days ago
Try DataVare PST to Office 365 Converter if you are looking for a quick and easy way to import PST files into Office 365. Compared to using Microsoft tools like AzCopy and CSV files or the manual Outlook technique, it is far simpler. There are no technical procedures required while using this application, simply choose your PST file, enter your Office 365 login, and the import begins. It functions with Primary, Archive, and Shared mailboxes and supports one or more PST files. It is ideal for people and companies seeking a simple, fast solution. Additionally it provides a free Demo version.
