berkscompsltd
Connection failed:
SQLstate: 'HY000'
SQL Server Error: 0
[Microsoft][ODBC SQL Server Driver] Cannot Generate SSPI Content
berkscompsltd
I can connect to the other SQL server instance on the same server no problem.
I can connect locally...
What's going on?
berkscompsltd
The SQL Server Network Interface library could not register the Service Principal Name (SPN) is also showing
berkscompsltd
After messing about with kerberos utilities and SPNs I had to configure the NAV server to use the SQL logins to get around this as I never figured out why it would start behaving this way - it was something to do with the dynamic ports and there being a static 2008 SQL server instance on the same box. Bluugh!
