8 years ago
Is there a way I can convert a Linux Dovecot/Postfix/Roundcube Maildir folder into a PST file so that we can read it in Microsoft Outlook?
We have tried Python Scripts and logging onto the IMAP server but no matter what we set the usernames and passwords to with DoveAdm or Apache or however we set the folder permissions it will not let us login.
We eventually did this with Thunderbird
We downloaded the latest version of the import/export tools
Copied the users /maildir folder onto an exFAT disk partition and then just used the tools\import export tools feature to copy each mailbox into Thunderbird - we had to do the sub-folders independently but apart from that it was a relatively painless process. We then used an MBOX converter to get PST files from the Thunderbird files.
Douglasreed54
You can use the manual method to convert Maildir to PST files, but it is not user-friendly and can not be appropriate for all users. To convert Maildir files to PST files, use the knowledgeable solution, Softaken Maildir Converter Tool. All users can utilize it with ease because it is a friendly application. Maildir files can be converted to HTML, PDF, MSG, PST, and EML. When converting Maildir files to Outlook PST files, no data is lost. Every Maildir message is saved and converted to Outlook PST format. All Maildir data can be converted to an Outlook PST file with attachments. It converts maildir files for any email client.
piterpark61
Convert Maildir files to Outlook PST files with the help of the BetaVare Maildir Converter Tool, a professional solution. Converting infinite Maildir data to Outlook PST file format is hassle-free and simple for all users. Maildir files are converted into multiple file format types including EML, MSG, MBOX, PST, PDF, and HTML. It doesn't lose any data when converting Maildir files to Outlook PST files. Every Maildir message is saved, and it is converted into Outlook PST files. Everything stored in Maildir can be converted to an Outlook PST file including attachments. Maildir files are converted for use with other email clients.
The thing is though that there are so many crap mail conversion softwares around nowadays that even forums get spammed with their nonsense daily. I just had to edit more links out of these two messages. People seem to have no imagination anymore - tehy all write the same crap software.
