Hi!! i have the same problem with this model, sometimes works for me , shutdown, power on, enter bios, disable wifi , login windows, shutdown, power on, enter bios, enable wifi, login windows and works for a few days or hours, i asked to asus support and the solution y change mainboard because wifi adapter y integrated on this, but definitively is a hardware problem, finally i change the computer, but always looking if there is any solution.
