I am having an issue with myu Windows PC
The start menu just keep rolling back to the beginning when I let go of all of the keys and mouse.
It is affecting drop-down menus on the web as they close instantly when I try to use them.
What can I do?
I have restarted and all the usual jazz....?
Do you have a wireless Xbox xontroller plugged in or a wireless mouse or keyboard?
Sometimes the Windows system detects a movement and it doesn't detect the cancel. Try unplugging your Xbox controller or unplugging you USB dongle for you wireless mouse or keyboard and then plug it back into a different USB slot so that the system has to reconfigure the direction inputs from scratch.
How did you know that so fast?
Thanks, worked a treat!
