Trying to repair an Exchange 2016 databse with ESEUtil /r receiving - Operation terminated with error -1022 (JET_errDiskIO, Disk IO error) after 0.16 seconds.
it this a space problem?
  • Newbie
I have more from the log - I made a repair with the /r option but the system complains with the error.
I then ran a /s and that went through but I still cannot run the /r to fix the log files - it is not a disk issue so what is it?
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ESEUTIL /r E00 /l "F:\ExchangeDatabases\DB01_Log\" /d "G:\ExchangeDatabases\DB01\DB01.edb"
Extensible Storage Engine Utilities for Microsoft(R) Exchange Server
Version 15.01
Copyright (C) Microsoft Corporation. All Rights Reserved.
Initiating RECOVERY mode...
    Logfile base name: E00
            Log files: F:\ExchangeDatabases\DB01_Log" /d G:\ExchangeDatabases\DB01\DB01.edb
         System files:
Performing soft recovery...
Version 15.01
         System files:
Version 15.01
         System files:
Operation terminated with error -1022 (JET_errDiskIO, Disk IO error) after 0.15 seconds.
Version 15.01
         System files:
C:\Windows\system32>ESEUTIL /p "G:\ExchangeDatabases\DB01\DB01.edb"
Version 15.01
Initiating REPAIR mode...
        Database: G:\ExchangeDatabases\DB01\DB01.edb
  Temp. Database: TEMPREPAIR19056.EDB
Checking database integrity.
The database is not up-to-date. This operation may find that
this database is corrupt because data from the log files has
yet to be placed in the database.
To ensure the database is up-to-date please use the 'Recovery' operation.
                     Scanning Status (% complete)
          0    10   20   30   40   50   60   70   80   90  100
Scanning the database catalog.
Rebuilding MSysObjects.
Rebuilding MSysObjectsShadow from MSysObjects.
Checking the database.
Scanning the database.
Repairing damaged tables.
Repair completed. Database corruption has been repaired!
Note:
  It is recommended that you immediately perform a full backup
  of this database. If you restore a backup made before the
  repair, the database will be rolled back to the state
  it was in at the time of that backup.
Operation completed successfully with 595 (JET_wrnDatabaseRepaired, Database corruption has been repaired) after 838641.938 seconds.
Version 15.01
         System files:
C:\Windows\system32>f:
F:\>dir
 Volume in drive F is Database 1 Logs
 Volume Serial Number is 4ABB-3402
 Directory of F:\
28/01/2022  17:00       158,552,064 Exchange2016-KB5008631-x64-en.msp
13/03/2018  14:28              ExchangeDatabases
26/01/2022  13:10     7,127,115,776 ExchangeServer2016-x64-CU22.ISO
28/06/2022  12:33              PSTExport
               2 File(s)  7,285,667,840 bytes
               2 Dir(s)  229,051,342,848 bytes free
F:\>g:
G:\>dir
 Volume in drive G is Exch Database 1
 Volume Serial Number is DED2-6617
 Directory of G:\
07/03/2021  12:59              42bdde288e818ad2226e00
25/04/2018  09:45              ExchangeDatabases
               0 File(s)              0 bytes
               2 Dir(s)  638,084,554,752 bytes free
G:\>ESEUTIL /r E00 /l "F:\ExchangeDatabases\DB01_Log\" /d "G:\ExchangeDatabases\DB01\DB01.edb"
Version 15.01
         System files:
G:\>ESEUTIL /p "G:\ExchangeDatabases\DB02\DB02.edb"
Version 15.01
        Database: G:\ExchangeDatabases\DB02\DB02.edb
  Temp. Database: TEMPREPAIR10668.EDB
  • Newbie
Seeing this:
error
Failed to mount database "DB02". Error: An Active Manager operation failed. Error: The database action failed. Error: Operation failed with message: MapiExceptionDatabaseError: Unable to mount database. (hr=0x80004005, ec=1108) Diagnostic context: Lid: 65256 Lid: 10722 StoreEc: 0x454 Lid: 1494 ---- Remote Context Beg ---- Lid: 1238 Remote Context Overflow Lid: 34760 StoreEc: 0xFFFFFDF0 Lid: 41344 Guid: 8329bbad-2244-40c8-bacf-542f0d0f9a7e Lid: 35200 dwParam: 0x4B24 Lid: 59596 dwParam: 0x411E67C7 Msg: JI20 Lid: 43212 dwParam: 0x411E67C7 Msg: JT05 Lid: 43212 dwParam: 0x411E67C7 Msg: JT08 Lid: 59596 dwParam: 0x411E67C7 Msg: WM19 Lid: 59596 dwParam: 0x411E67C7 Msg: WM20 Lid: 59596 dwParam: 0x411E67C7 Msg: WM21 Lid: 54472 StoreEc: 0x980 Lid: 42184 StoreEc: 0x454 Lid: 10786 dwParam: 0x0 Msg: 15.01.2375.018:Exch01:8329bbad-2244-40c8-bacf-542f0d0f9a7e Lid: 51578 Guid: 8329bbad-2244-40c8-bacf-542f0d0f9a7e Lid: 1750 ---- Remote Context End ---- Lid: 1047 StoreEc: 0x454 [Database: DB02, Server: Exch01.domain.local]
