  • andrewt2m
SharePoint server 2016 search crawl error:
The content processing pipeline failed to process the item. ( ExpandSegments; ; SearchID = D04AFF02-00E2-4DB9-8170-517BBD00980F )
Fails to search every item since a certain update or something...?
Should I reset the index do you think?
  • andrewt2m
Reset content search database to no avail
  • andrewt2m
re-running the farm configuration wizard may be a solution as we have applied service packs to the SQL server and it may need to be re-aligned as suggested in expert sex change.
  • andrewt2m
We are going to try and recreate the search app just using the GUI run as admin.
Highlight search application.
click delete
Await completion.
Run farm configuration - it will tick the Search Application box.
Proceed.
Await completion.
Await the content sources to be populated.
Run a full crawl - voila!
