  • andrewt2m
SharePoint server 2016 search crawl error:
The content processing pipeline failed to process the item. ( ExpandSegments; ; SearchID = D04AFF02-00E2-4DB9-8170-517BBD00980F )
Fails to search every item since a certain update or something...?
Should I reset the index do you think?
  • andrewt2m
Reset content search database to no avail
  • andrewt2m
re-running the farm configuration wizard may be a solution as we have applied service packs to the SQL server and it may need to be re-aligned as suggested in expert sex change.
  • andrewt2m
We are going to try and recreate the search app just using the GUI run as admin.
Highlight search application.
click delete
Await completion.
Run farm configuration - it will tick the Search Application box.
Proceed.
Await completion.
Await the content sources to be populated.
Run a full crawl - voila!
6 months ago
The error message "The content processing pipeline failed to process the item" in Microsoft Search, SharePoint, or Windows Search typically indicates an issue with indexing, crawling, or processing content in the search pipeline. The ExpandSegments error suggests that the system encountered a problem breaking down the indexed content into searchable segments.
πŸ”Ή Possible Causes of This Error
1. Corrupt or Unreadable Content
  • The file being indexed may be corrupted, improperly formatted, or an unsupported file type.
  • Some PDFs, Word documents, or custom file types may have metadata or encoding issues.
2. Insufficient Permissions
  • The indexing service doesn’t have permission to access the file or content.
  • Check the user/group permissions to ensure that the search service account has full read access.
3. Search Index Corruption
  • The SharePoint, Windows, or SQL search index may have become corrupted.
  • Resetting or re-crawling the index can help fix this.
4. Large or Complex Files
  • Extremely large files or documents with complex structures (tables, embedded content, unusual formatting) can cause segmentation failures.
5. Faulty Search Service Components
  • The search service may have a misconfiguration, missing components, or outdated settings.
  • Restarting the Search Service can sometimes fix this.
πŸ”Ή Solutions to Fix the Issue
πŸ”Έ 1. Check Event Viewer for More Details
  • Open Event Viewer (eventvwr.msc).
  • Go to Windows Logs β†’ Application or SharePoint Logs.
  • Look for additional error codes or messages related to the search service.
πŸ”Έ 2. Restart Search Services
If this is a Windows Search or SharePoint Search issue, restart the services:
Restart-Service WSearch  # Windows Search Service
Restart-Service SPSearch4 # SharePoint Search Service (if applicable)
For SQL Search:
EXEC msdb.dbo.sp_fulltext_service 'restart_all_services';
πŸ”Έ 3. Reset Search Index (For SharePoint or Windows Search)
⚠️ Warning: This will clear and rebuild the entire index.
Stop-Service SPSearch4
Remove-Item -Path "C:\ProgramData\Microsoft\Search\Data\Applications\Windows\Windows.edb" -Force
Start-Service SPSearch4
For SharePoint:
Get-SPEnterpriseSearchServiceApplication | Reset-SPEnterpriseSearchIndex
πŸ”Έ 4. Verify File & Permissions
  1. Check the file's location and ensure the search service account has read permissions.
  2. Try manually opening the fileβ€”if it’s corrupt, it may need to be removed or repaired.
πŸ”Έ 5. Increase Processing Timeout for Large Files
If the error occurs with large or complex files, you may need to increase timeout limits.
For SharePoint
Set-SPEnterpriseSearchCrawlConfiguration -SearchApplication "Search Service Application" -TimeoutForRetrievingItems 300
For Windows Search Registry Tweak
Increase the processing timeout for search in Registry Editor:
  1. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Search
  2. Add a DWORD key: MaxIndexingTimeout
  3. Set it to 60000 (for 60 seconds)
πŸ”Έ 6. Exclude Problematic Files
If certain files are causing repeated failures, you can exclude them from indexing:
  1. Open Indexing Options in Control Panel.
  2. Click Modify β†’ Uncheck problematic directories.
  3. Restart the Windows Search service.
πŸ”Ή Final Steps
βœ” Check Event Logs for deeper error details
βœ” Restart search services
βœ” Verify file accessibility & permissions
βœ” Reset the search index if corruption is suspected
βœ” Increase processing time for large files
βœ” Exclude problematic files if necessary
If the issue persists, let me know what platform you're using (SharePoint, Windows Search, SQL, etc.), and I can provide more specific troubleshooting steps! πŸš€
