What should we do - inform the manufacturer?
Source: MR_MONITOR
Date: 18/11/2020 13:57:24
Event ID: 431
Task Category: 4.
Computer: GRNAS01.domain.local
Controller ID: 0 Battery charging was suspended due to high battery temperature.
431
1085
This is mostly likely the firmware that needs updating - you need a minimum firmware version of 21.3.0-0009 or later if you have an H710 or H810
Otherwise, yes inform the manufacturer.
