We are seeing these 1202 0x534 errors every 5 minutes on our 2019 server new DC
I cannot see any of the WdiService users described in the Microsoft Fix đŸ˜£
Source: SceCli
Date: 18/09/2020 22:44:19
Event ID: 1202
Computer: DC.domain.local
Security policies were propagated with warning. 0x534 : No mapping between account names and security IDs was done.
Error 0x534 occurs when a user account in one or more Group Policy objects (GPOs) could not be resolved to a SID. This error is possibly caused by a mistyped or deleted user account referenced in either the User Rights or Restricted Groups branch of a GPO. To resolve this event, contact an administrator in the domain to perform the following actions:
1. Identify accounts that could not be resolved to a SID:
From the command prompt, type: FIND /I "Cannot find" %SYSTEMROOT%\Security\Logs\winlogon.log
The string following "Cannot find" in the FIND output identifies the problem account names.
Example: Cannot find JohnDough.
In this case, the SID for username "JohnDough" could not be determined. This most likely occurs because the account was deleted, renamed, or is spelled differently (e.g. "JohnDoe").
2. Use RSoP to identify the specific User Rights, Restricted Groups, and Source GPOs that contain the problem accounts:
a. Start -> Run -> RSoP.msc
b. Review the results for Computer Configuration\Windows Settings\Security Settings\Local Policies\User Rights Assignment and Computer Configuration\Windows Settings\Security Settings\Local Policies\Restricted Groups for any errors flagged with a red X.
c. For any User Right or Restricted Group marked with a red X, the corresponding GPO that contains the problem policy setting is listed under the column entitled "Source GPO". Note the specific User Rights, Restricted Groups and containing Source GPOs that are generating errors.
3. Remove unresolved accounts from Group Policy
a. Start -> Run -> MMC.EXE
b. From the File menu select "Add/Remove Snap-in..."
c. From the "Add/Remove Snap-in" dialog box select "Add..."
d. In the "Add Standalone Snap-in" dialog box select "Group Policy" and click "Add"
e. In the "Select Group Policy Object" dialog box click the "Browse" button.
f. On the "Browse for a Group Policy Object" dialog box choose the "All" tab
g. For each source GPO identified in step 2, correct the specific User Rights or Restricted Groups that were flagged with a red X in step 2. These User Rights or Restricted Groups can be corrected by removing or correcting any references to the problem accounts that were identified in step 1.
1202
371
DC0.domain.local
https://support.microsoft.com . Query for "troubleshooting 1202 events".
We have updated our Domain Controller default policy from a 2008 R2 box but that was a long time ago.
t2m
  • t2m
  • 53.8% (Neutral)
  • Newbie
This error indicates that there are AD users specified in the group policy for the Default Domain Controllers that can no longer be found in AD.
If you do [Windows] + R for RUN and enter RSOP.msc and run it you can see which Group Policies are creating this:
On the domain controller default policy it tends to be users added to the local policies\user rights assignment:
Once the non-existent users are removed, run GPUpdate and see if the error ceases.
That's great - I now see this information event instead:
Source: SceCli
Date: 20/09/2020 20:32:23
Event ID: 1704
Level: Information
Computer: DC0.domain.local
Security policy in the Group policy objects has been applied successfully.
1704
957
DC0.domain.local
