This is what we are seeing:
Source: ASP.NET 4.0.30319.0
Date: 09/04/2020 13:21:41
Event ID: 1309
Task Category: Web Event
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 09/04/2020 13:21:37
Event time (UTC): 09/04/2020 12:21:37
Event ID: bca651d816984d76b21282477dcc0551
Event sequence: 41
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/4/ROOT-1-132309077984115047
Trust level: Full
Application Virtual Path: /
Application Path: E:\Websites\www\websitename\
Machine name: %computername%
Process information:
Process ID: 1928
Process name: w3wp.exe
Account name: IIS APPPOOL\websitename
Exception information:
Exception type: DbUpdateException
Exception message: An error occurred while updating the entries. See the inner exception for details.
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Microsoft.AspNet.Identity.EntityFramework.UserStore`1.d__0.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at Microsoft.AspNet.Identity.EntityFramework.UserStore`1.d__5.MoveNext()
at Microsoft.AspNet.Identity.UserManager`1.d__0.MoveNext()
at Microsoft.AspNet.Identity.UserManager`1.d__10.MoveNext()
at Microsoft.AspNet.Identity.AsyncHelper.RunSync[TResult](Func`1 func)
at Account_Register.CreateUser_Click(Object sender, EventArgs e) in E:\Websites\www\websitename\account\Register.aspx.vb:line 14
at System.Web.UI.WebControls.Button.OnClick(EventArgs e)
at System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Data.Entity.Core.Mapping.Update.Internal.UpdateTranslator.d__0.MoveNext()
at System.Data.Entity.Core.Objects.ObjectContext.d__3b`1.MoveNext()
at System.Data.Entity.Core.Objects.ObjectContext.d__37.MoveNext()
at System.Data.Entity.SqlServer.DefaultSqlExecutionStrategy.d__9`1.MoveNext()
at System.Data.Entity.Core.Objects.ObjectContext.d__2f.MoveNext()
Failed to update database "aspnet-WebSite2-c7587fd6-c91e-41cd-abb6-4e6de0d61e21" because the database is read-only.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.CompleteAsyncExecuteReader(Boolean isInternal, Boolean forDescribeParameterEncryption)
at System.Data.SqlClient.SqlCommand.InternalEndExecuteNonQuery(IAsyncResult asyncResult, String endMethod, Boolean isInternal)
at System.Data.SqlClient.SqlCommand.EndExecuteNonQueryInternal(IAsyncResult asyncResult)
at System.Data.SqlClient.SqlCommand.EndExecuteNonQueryAsync(IAsyncResult asyncResult)
at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
at System.Data.Entity.Core.Mapping.Update.Internal.DynamicUpdateCommand.d__0.MoveNext()
Request information:
https://www.internetadvice.co.uk:443/Account/Register
Request path: /Account/Register
User host address: x.x.x.x
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\websitename
Thread information:
Thread ID: 64
Thread account name: IIS APPPOOL\websitename Is impersonating: False
Stack trace: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
Custom event details:
1309
2294180
3005
09/04/2020 13:21:37
09/04/2020 12:21:37
41
1
Full
%computername%
1928
w3wp.exe
DbUpdateException
at Microsoft.AspNet.Identity.EntityFramework.UserStore`1.<SaveChanges>d__0.MoveNext()
at Microsoft.AspNet.Identity.EntityFramework.UserStore`1.<CreateAsync>d__5.MoveNext()
at Microsoft.AspNet.Identity.UserManager`1.<CreateAsync>d__0.MoveNext()
at Microsoft.AspNet.Identity.UserManager`1.<CreateAsync>d__10.MoveNext()
at System.Data.Entity.Core.Mapping.Update.Internal.UpdateTranslator.<UpdateAsync>d__0.MoveNext()
at System.Data.Entity.Core.Objects.ObjectContext.<ExecuteInTransactionAsync>d__3b`1.MoveNext()
at System.Data.Entity.Core.Objects.ObjectContext.<SaveChangesToStoreAsync>d__37.MoveNext()
at System.Data.Entity.SqlServer.DefaultSqlExecutionStrategy.<ExecuteAsyncImplementation>d__9`1.MoveNext()
at System.Data.Entity.Core.Objects.ObjectContext.<SaveChangesInternalAsync>d__2f.MoveNext()
at System.Data.Entity.Core.Mapping.Update.Internal.DynamicUpdateCommand.<ExecuteAsync>d__0.MoveNext()
/Account/Register
83.244.231.200
False
64
False
Any ideas?
This is not a database error.
Try recreating the website in a different folder and recreating the website app in IIS also.
It is sometimes a log file stuck in IIS ASP4 folders that is per site and a new site with exactly the same files including webconfig etc. will solve the issues but keep all of the custom errors etc.
