Seeing this upon application opening:
SSPI handshake failed with error code 0x8009030c, state 14 while establishing a connection with integrated security; the connection has been closed. Reason: AcceptSecurityContext failed. The Windows error code indicates the cause of failure. [CLIENT: 192.168.x.x]
Is this using integrated security instead of SQL, is that the issue?
Have the SPNs been correctly created in Active Directory.
This may help:
SPNs in active directory
