Joined: 14/04/2021(UTC) Posts: 36  Location: Reading Was thanked: 1 time(s) in 1 post(s)
What can I do to speed up Outlook opening?
I am on SSDs and we have a fast dedicated internet but I cannot get in to Outlook in less than 5-10 minutes.
I have maybe 6 or 7 on-line and on-premises accounts with Exchange 2019 & Office 365
Joined: 08/01/2017(UTC) Posts: 743  Location: London Thanks: 22 times Was thanked: 12 time(s) in 10 post(s)
Reduce the mailbox size and/or the number of accounts you have open.
Check the add-ins you are using under options\add-ins.
Reduce the number of months of downloaded data on the accounts.
Move the data files to a separate disk, preferably an SSD that is not the system disk.
More RAM
More CPU power
Use web mail for some of the accounts if you do not need a lot of features and do not check the mail often. |
Rank: Member
Joined: 25/10/2021(UTC) Posts: 20  Location: Essex Thanks: 1 times
It was the Dynamics CRM add-in that was causing this issue. I had to move the CRM website into the Intranet zone and change the authentication to used current username and password to get it working.
Important Information:
The PC & Mac Help and Assistance uses cookies. By continuing to browse this site, you are agreeing to our use of cookies.
More Details
Close
