#1 Posted : 23 February 2021 14:30:29(UTC)
This is connected to my last post:
Cannot use USB disk with a Hyper-V VM
This is the error when the VM is already running and I try and add the disk
Host 2016
VM 2016
Adding the device 'Microsoft:Hyper-V:Physical Disk Drive' to VM Failed
Log Name: Microsoft-Windows-Hyper-V-VMMS-Admin
Source: Microsoft-Windows-Hyper-V-VMMS
Date: 23/02/2021 14:20:27
Event ID: 14140
Keywords:
User: SYSTEM
Computer: host.domain.local
'VM' failed to add device 'Physical Disk Drive'. (Virtual machine ID CBD00B13-D1DF-4A59-8D3C-0F9CEE14934C)
<Provider Name="Microsoft-Windows-Hyper-V-VMMS" Guid="{6066F867-7CA1-4418-85FD-36E3F9C0600C}" />
<EventID>14140</EventID>
<TimeCreated SystemTime="2021-02-23T14:20:27.259479800Z" />
<EventRecordID>1532</EventRecordID>
<Execution ProcessID="2444" ThreadID="8696" />
<Channel>Microsoft-Windows-Hyper-V-VMMS-Admin</Channel>
<Computer>host.domain.local</Computer>
<UserData>
<VmlEventLog xmlns="http://www.microsoft.com/Windows/Virtualization/Events">
<VmName>HappyHub</VmName>
<VmId>CBD00B13-D1DF-4A59-8D3C-0F9CEE14934C</VmId>
<Parameter0>Physical Disk Drive</Parameter0>
</VmlEventLog>
</UserData>
Edited by user 23 February 2021 15:12:55(UTC)  | Reason: Not specified
or PayPal with This Link
#2 Posted : 23 February 2021 15:12:27(UTC)
Ooops
It was the wrong disk Whistle
That one was in use as a backup for something else.
Trustpilot
