#1 Posted : 13 December 2019 17:44:02(UTC)
I have an Apple Macbook A1466 which does not appear to be charging.
...It does not power on either, it just shows the dreaded battery dead sign when first plugged-in but does not illuminate the charger plug green as I would expect.
Even if I leave the charger plugged in for hours there is no change.
Do I need a new battery, or is it more serious?
I have tried different chargers to no avail.
Thanks
See below:
Macbook shows dead battery icon
Edited by user 13 December 2019 17:52:54(UTC)  | Reason: added image of laptop
