#1 Posted : 16 July 2019 09:51:29(UTC)
I have an ML110 G9 that we have installed Windows 2016 server essentials on.
The system works just fine, but the device manager shows two Base system device elements showing as requiring a driver.
Is this the iLO or some other element?
Is there a driver that will work?
HP seem to have forced all of their support to subscription only which makes me think we will not buy another but can I find the driver without their help?
Many thanks :)
#2 Posted : 16 July 2019 12:03:59(UTC)
It was the iLO - I installed the following and it solved the uninstalled driver issue in device manager:
iLO 3/4 Management Controller Driver Package for Windows Server 2016
https://support.hpe.com/hpsc/swd/public/detail?swItemId=MTX_92195f98e69042589cfd15ebe2&swEnvOid=4231
https://support.hpe.com/hpsc/swd/public/detail?swItemId=MTX_c5e0ed82c4864327bc9b86442c&swEnvOid=4231
Edited by user 16 July 2019 12:05:59(UTC)  | Reason: Not specified
