#1 Posted : 30 August 2018 15:16:22(UTC)
Was thanked: 9 time(s) in 9 post(s)
This website uses an insecure connection.
This website uses an insecure encryption protocol, and your connection may not be private.
This problem might indicate an attempt to intercept any data you send to the server.
How can I visit the site?
I have enabled SSL 3.0 and added it as a safe site but still no joy...?
or PayPal with This Link
Offline andrewt2m
#2 Posted : 09 November 2021 16:54:25(UTC)
This is an issue with the website itself. Usually because it is being run on something like Windows server 2008 or 2008 R2 which uses old cyphers which you need to disable.
If you are the administrator of the web server then you can take the appropriate action quite easily using the tool available here: https://www.nartac.com/Products/IISCrypto/
Trustpilot
