#1 Posted : 16 November 2020 11:43:40(UTC)
Was thanked: 12 time(s) in 10 post(s)
How can we solve this issue with Server 2008 R2?
We are receiving a message when using OWA on our Exchange 2007 server:
Your connection is not fully secure
This site uses an outdated security configuration, which may expose your information (for example, passwords, messages, or credit cards) when it is sent to this site.
NET::ERR_SSL_OBSOLETE_VERSION
Your connection is not fully secure NET::ERR_SSL_OBSOLETE_VERSION
Edited by user 16 November 2020 11:44:58(UTC)  | Reason: Not specified
or PayPal with This Link
Offline sirclesadmin
#2 Posted : 18 November 2020 15:46:15(UTC)
Rank: Administration
Groups: Administrators
Was thanked: 23 time(s) in 20 post(s)
It should be as simple as the following:
Click the start button
Type Regedit
Right click the Regedit icon presented and choose 'Run as administrator'
In the left hand pane, browse down to: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols
Create two new keys, which resemble folders in Windows Explorer, called TLS 1.1 and TLS 1.2
In each key, create the following DWORD 32 bit values called:
DisabledByDefault Set the value to 0
Enabled Set the value to 1
Press Windows Button + R and enter IISReset into the Run box and press enter.
Trustpilot
