jennumaria
Yes, you can! With Advik MSG Converter, there's no need to install or use Microsoft Outlook to import MSG to Office 365 . The software is designed to work independently and directly transfers MSG files to your Office 365 account. This is especially useful if you’ve backed up MSG files but don’t have Outlook installed on your current device. You can upload and access your emails in Office 365 without any technical setup.
If you really are tight enough to do an Exchange only deal on 365 so that you do not get Outlook included, would you really pay the fee to unlock this thing to import your email? I don't think it makes sense.
Charlee Nunez
25 days ago
Are you looking for a way to import MSG files to Office 365 without using Outlook? Then try FixVare MSG to Office 365 Importer, which provides a direct solution to import MSG files to an Office 365 account. The tool easily imports a bulk MSG file into an Outlook 365 account at once. Complete the errorless process in just a few clicks without Outlook Installation. It supports Windows version 11 and all previous versions. It safely and accurately loads all files to Office 365 using only the login ID and password details.
https://www.fixvare.com/products/msg/office365/
