If your Hyper-V virtual machine (VM) is stuck in "Backing Up" status and you can't start it, it usually indicates an issue with backup integration services, VSS (Volume Shadow Copy Service), or a failed backup attempt. Since you mentioned the backup doesn't run this early, it's likely a stuck backup operation or a miscommunication between Hyper-V and the backup software.
Possible Causes & Solutions
1. Stuck Backup or Previous Snapshot Issue
Sometimes, Hyper-V gets stuck in "Backing Up" mode due to a failed or incomplete backup.
🔹 Solution: Restart Hyper-V Virtual Machine Management Service
- Open Command Prompt (Admin) or PowerShell and run:
net stop vmms
net start vmms
- This restarts the Hyper-V Virtual Machine Management Service without rebooting the host.
- Check if the VM is now accessible.
2. Check for Active VSS Snapshots
A snapshot (checkpoint) might be causing the issue if it's still open.
🔹 Solution: Check for stuck VSS snapshots
- Open Command Prompt (Admin) and run:
vssadmin list shadows
- If you see a snapshot related to the VM, try deleting it:
vssadmin delete shadows /all
- If the VM is still stuck, restart the Hyper-V Volume Shadow Copy Requestor service.
3. Check Windows Backup or Third-Party Backup Software
A third-party backup tool (like Veeam, Acronis, or Windows Server Backup) might be trying to take a backup.
🔹 Solution: Restart the Backup Service
- Identify the backup software in use.
- Restart the related services (e.g., Veeam Backup Service, Windows Server Backup, or other backup tools).
- Check the backup logs to see if there was a failed attempt.
4. Manually Remove a Stuck Checkpoint
Hyper-V may have created a checkpoint (snapshot) that is causing the issue.
🔹 Solution: Delete the stuck checkpoint manually
- Open Hyper-V Manager.
- Check if the VM has a stuck checkpoint under Checkpoints.
- If there is one, delete it.
- If you can't delete it via GUI, use PowerShell:
Get-VMSnapshot -VMName "YourVMName" | Remove-VMSnapshot
5. Force Stop the VM and Restart
If all else fails, try forcefully stopping and restarting the VM.
🔹 Solution: Force Stop the VM
- Open Task Manager.
- Look for vmwp.exe (Virtual Machine Worker Process).
- Find the process related to your VM (check Process ID in Hyper-V Manager).
- End Task for that specific VM.
- Try starting the VM again.
Final Thoughts
- If the issue is caused by a stuck backup, restarting the VMMS service usually fixes it.
- If a backup is truly running (even though it shouldn’t be), check your backup software logs.
- If none of these solutions work, consider restarting the Hyper-V host (as a last resort).
Let me know if you need further troubleshooting! 🚀
