We have recently had to repair our server with some new hardware which caused us to do a quick rebuild of the system drive.
All of the installed software was retained though and all the service packs have been returnted to their original state.
We are now seeing the following error though:
C/SIDE hyperlinking failed.
You tried to hyperlink to this target:
\\serverpath\share\doc.ext
Do you want to place that hyperlink target on the clipboard?
Yes No
This is with a JPEG extension which does not seem to appear in our FIN.STX file but if we add it manually we get a checksum error.
Has anyone got any ideas about what we should do?
NAV version is 2009 running on an SBS 2003 SP2 server and the clients are XP, Vista or Win 7
Many thanks in advance for any ideas or help.
Want to thank us? Use: Patreon or PayPal or Bitcoins: 3GJia7gLLY8V8eYBf5Q3RjCrNV8kZC3aNn
Just use JPG as your extension and you won't see this.
