We can't connect to your Microsoft Dynamics 365 server. Please inform your system administrator that trusted secure sockets layer (SSL) certificates are required.
Metadata contains a reference that cannot be resolved:
....://disco.crm11.dynamics.com/XRMServices/2011/Discovery.svc?wsdl...
at
Microsoft.CRM.Application.Outlook.Config.DeploymentsInfo'1.LoadOr...
uiMode, Control ParentWindow)
at
Microsoift.CRM.Application.Outlook.Config.ServerForm.LoadOrganization ForceUI,String deploymentURL, Boolean tryWIA)
at
System.ComponentModel.BackgroundWorker.OnDoWork(doWorkEve...
e)
at
System.ComponentModel.BackgroundWorkerThreadStart(Obje...
argument)
 image.png You have insufficient rights to see the content.
Log file output:
https://disco.crm8.dynamics.com/XRMServices/2011/Discovery.svc  Exception: System.InvalidOperationException: Metadata contains a reference that cannot be resolved: 'https://disco.crm8.dynamics.com/XRMServices/2011/Discovery.svc?wsdl&sdkversion=9'. ---> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
   at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, Exception exception)
   at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest, Boolean renegotiation)
   at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result)
   at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size)
   at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size)
   at System.Net.ConnectStream.WriteHeaders(Boolean async)
   --- End of inner exception stack trace ---
   at System.Net.HttpWebRequest.GetResponse()
   at System.ServiceModel.Description.MetadataExchangeClient.MetadataLocationRetriever.DownloadMetadata(TimeoutHelper timeoutHelper)
   at System.ServiceModel.Description.MetadataExchangeClient.MetadataRetriever.Retrieve(TimeoutHelper timeoutHelper)
   at System.ServiceModel.Description.MetadataExchangeClient.ResolveNext(ResolveCallState resolveCallState)
   at System.ServiceModel.Description.MetadataExchangeClient.GetMetadata(MetadataRetriever retriever)
   at Microsoft.Xrm.Sdk.Client.ServiceMetadataUtility.RetrieveServiceEndpointMetadata(Type contractType, Uri serviceUri, Boolean checkForSecondary)
   at Microsoft.Xrm.Sdk.Client.ServiceConfiguration`1..ctor(Uri serviceUri, Boolean checkForSecondary)
   at Microsoft.Xrm.Sdk.Client.ServiceConfigurationFactory.CreateConfiguration[TService](Uri serviceUri, Boolean enableProxyTypes, Assembly assembly)
   at Microsoft.Crm.Outlook.ClientAuth.ClientAuthProvidersFactory`1.DiscoverAuthUsingServiceMetadata(Uri endPoint, Uri webEndPoint)
   at Microsoft.Crm.Outlook.ClientAuth.ClientAuthProvidersFactory`1.GetAuthProviderForDeployment(Uri endPoint, Uri webEndPoint)
   at Microsoft.Crm.Application.Outlook.Config.DeploymentsInfo`1.DeploymentInfo`1.ValidateAuthProvider()
   at Microsoft.Crm.Application.Outlook.Config.DeploymentsInfo`1.SortAndValidateDeployments()
https://disco.crm.microsoftdynamics.de/XRMServices/2011/Discovery.svc  Exception: System.InvalidOperationException: Metadata contains a reference that cannot be resolved: 'https://disco.crm.microsoftdynamics.de/XRMServices/2011/Discovery.svc?wsdl&sdkversion=9'. ---> System.Net.WebException: The remote name could not be resolved: 'disco.crm.microsoftdynamics.de'
https://disco.crm11.dynamics.com/XRMServices/2011/Discovery.svc  Exception: System.InvalidOperationException: Metadata contains a reference that cannot be resolved: 'https://disco.crm11.dynamics.com/XRMServices/2011/Discovery.svc?wsdl&sdkversion=9'. ---> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
12:20:30|  Error| Exception : Metadata contains a reference that cannot be resolved: 'https://disco.crm11.dynamics.com/XRMServices/2011/Discovery.svc?wsdl&sdkversion=9'.    at Microsoft.Crm.Application.Outlook.Config.DeploymentsInfo`1.LoadOrganizations(AuthUIMode uiMode, Control parentWindow)
   at Microsoft.Crm.Application.Outlook.Config.ServerForm.LoadOrganizationsInternal[TService](Boolean forceUI, String deploymentUrl, Boolean tryWIA, Boolean keepUrlIntact, String org)
   at Microsoft.Crm.Application.Outlook.Config.ServerForm.LoadOrganizationsLogic(Boolean forceUI, String deploymentUrl, Boolean tryWIA)
   at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
   at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument) -2146233079
12:20:30|  Error| Exception : The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.    at System.Net.HttpWebRequest.GetResponse()
   at System.ServiceModel.Description.MetadataExchangeClient.MetadataRetriever.Retrieve(TimeoutHelper timeoutHelper) -2146233079
http://go.microsoft.com/fwlink/?LinkID=398563&lcid=409&cv=9.1.0.7250&opsys=10.0.22000.0&cid=f2a11970-f202-4044-a9cb-111ad3a73b7c&client=Outlook&error=System.InvalidOperationException%3a80131509%26System.Net.WebException%3a80131509%26System.Security.Authentication.AuthenticationException%3a80131501&method=LoadOrganizations%26GetResponse%26StartSendAuthResetSignal&st=%20%20%20at%20Microsoft.Crm.Application.Outlook.Config.DeploymentsInfo%601.LoadOrganizations%28AuthUIMode%20uiMode%2c%20Control%20parentWindow%29%0d%0a%20%20%20at%20Microsoft.Crm.Application.Outlook.Config.ServerForm.LoadOrganizationsInternalTService%28Boolean%20forceUI%2c%20String%20deploymentUrl%2c%20Boolean%20tryWIA%2c%20Boolean%20keepUrlIntact%2c%20String%20org%29%0d%0a%20%20%20at%20Microsoft.Crm.Application.Outlook.Config.ServerForm.LoadOrganizationsLogic%28Boolean%20forceUI%2c%20String%20deploymentUrl%2c%20Boolean%20tryWIA%29%0d%0a%20%20%20at%20System.ComponentModel.BackgroundWorker.OnDoWork%28DoWorkEventArgs%20e%29%0d%0a%20%20%20at%20System.ComponentModel.BackgroundWorker.WorkerThreadStart%28Object%20argument%29&orgType=&orgType=CRM  On-Premise
