  • andrewt2m
After replacing certificate we saw this on EX2019 DB box:
Source: MSExchange Front End HTTP Proxy
Date: 22/12/2021 13:08:39
Event ID: 2001
Task Category: Core
Computer: exserver.domain.local
[Owa] Failed to load SSL certificate.
2001
3495586
Owa
Date: 22/12/2021 13:08:59
Event ID: 2001
Task Category: Core
[Ecp] Failed to load SSL certificate.
2001
3495590
Ecp
  • andrewt2m
OK so there were a few issues here, firstly the Exchange Back End website had lost it's certificate association which stopped all comms with the Exchange server including powershell:
And so we could not change anything.
We had to repair the association with the site in the IIS manager bindings:
Once the certificate was reinstated, we ran IISReset on the server and then we regained access to Exchange PowerShell
We could then re-associate all of the services with the correct certificate using:
Enable-ExchangeCertificate -Thumbprint [Thumbprint] -Services POP,IMAP,IIS,SMTP
All we had to do after that was to re-associate the relationship with our edge-transport server as we use one, but otherwise you should be done. 🖐
