2 months ago
To change the Windows 11 version from 22H2 to 24H2 in the registry, you need to modify specific registry keys. First, navigate to the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion registry key. Then, locate the ReleaseId string value and change its data from "22H2" to "24H2". You may also need to create a new string value named TargetReleaseVersionInfo and set its data to "24H2". After making these changes, restart your computer to apply the modifications.
Here's a more detailed breakdown:
Open Registry Editor: Press the Windows key + R, type regedit, and press Enter.
Navigate to the key: Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion.
Modify ReleaseId: Double-click the ReleaseId string value and change its data to "24H2".
Create TargetReleaseVersionInfo: If the TargetReleaseVersionInfo string value doesn't exist, right-click in the right pane, select "New" -> "String Value", name it TargetReleaseVersionInfo, and set its data to "24H2".
Restart: Restart your computer for the changes to take effect.
Important considerations:
Back up the registry:
Before making any changes to the registry, it's crucial to back it up. You can do this by selecting "File" -> "Export" in Registry Editor.
Be careful:
Modifying the registry incorrectly can lead to system instability. Only make changes if you are confident in what you are doing.
Alternative methods:
You can also use the Windows 11 Installation Assistant or the Media Creation Tool to upgrade to 24H2 without directly editing the registry.
Hardware compatibility:
Ensure your hardware meets the minimum requirements for Windows 11 24H2.
Security:
Be cautious when downloading files or modifying your system based on information found online.
By following these steps, you can change the Windows version in the registry and potentially upgrade to 24H2.
